Originally Posted by baseballfanz
Green/Red sounds about right also the black coming out of the compass is a ground, you might just want to tap into that for ground. Make sure that ground is a good source. I know there's a metal frame above the console but that frame might not be in contact with any other metal source. If you have found a good source for 12V positive, use that on your + voltmeter probe and use the - probe to look for a good grounding source.
This is where mine is mounted with the conceal display near the gauge.
http://www.titantalk.com/forums/580007-post13.html
That looks awesome. Any issues with the mounting hardware coming lose?
