Re: How often to differential oil?
thats what i was going to do at or before the 30k mark. it all has to do with your use/abuse of the vehicle to determine your fluid change interval. obviously the more you do it the better, but it also costs more.
so you have to weight how often you use your vehicle and what kind of use its doing. i would lengthen the service intervals if you were doing a lot of highway driving and only start the truck under 5 times a day. if your doing a lot of hauling and towing or doing a lot of stop and go then your intervals would be shorter.
