Thread: stored gas
Old 09-25-2007, 01:29 PM   #10 (permalink)
cneary812
cneary812's Avatar
Re: stored gas
gasoline is made up of many different hydrocarbons. Some of the lighter more volitile components start to evaporate quickly while the heavier compounds stay behind. If anyone has seen a gummed up carb then they know what is left behind...
As long as you keep gas in a sealed container away from direct sunlight it should last a long time. If it has a chance to vent it will break down and go "bad" It will also absorb some water. The fuel stabilizers do extend the life greatly. Your best bet is to use some or just run it every once and a while to keep it fresh.
05 LE Crew Cab Smoke OR 4x4
airbox mod with K&N
Scangage2/blendmount
Roadmaster Active Suspension
future mods - JBA Evol , PRG leveling kit, 2* timing advance, Injen Powerflow, and more
cneary812 is offline   Reply With Quote
