Thread: backspace help
Old 09-30-2007, 01:44 PM   #3 (permalink)
NorCal 4x4
NorCal 4x4's Avatar
Re: backspace help
Originally Posted by 450ryder
i searched this forum and google to avail... im looking at new wheels for my truck and they have a weird backspace number system. can somebody please help me understand this? i want 22" that stick out about 1-3"
http://www.akuza.com/rwd_aka_455.htm
edit: i think i have it figured out. +18 offset 5.96 backspace will that fit?
Our bolt pattern is 6 on 5.5" or 6 on 139.7 mm. So it's the only one with a chance of fitting. It will stick in towards your steering knuckle an extra half an inch compared to the stock 18s, (could be an issue, check to see how much clearance you have now with a scrap of wood and measure). Since they are 9.5" wide and you'd stick in an extra 1/2", that means they would stick out 1" more, (plus any additional because of a wider tire). You might need to do the pinch weld mod for rubbing when you turn the steering wheel to full lock.
What tires are you planning for?
