Originally Posted by cohee3
Many times there are unintended consequences to your actions. I had an extra insect repellant wipe wrapped up in the foil bag and in my center console. The citronella smell permeated the console then the truck cab. I removed the wipe but the smell remained. I do not want to "contaminate" my hunting gear so while in the garage on Saturday afternoon, I decided to use the fob trick to lower the windows of my unlocked truck and air it out.
On Sunday, I needed something out of the cab. The driver's door was locked and my keys were upstairs. No problem... I reached in the open window and unlocked the truck using the door switch. I then opened the now unlocked driver's door. I do not know what the Titan horn decible level is, but it seems much higher in a closed garage. Fortunately the alarm times out after a while and I was able to lower myself from the ceiling without injury.
Wow, thanks for the warning on that one. That sounds like something I would do and then I'd have the same reaction as you!
285/70/17 BFGoodrich All-Terrain T/A KO
DIY Air Box Mod w/ Drop in AMSOIL EaA Air Filter
TomTom One XL Navigation
2* Timing Advance
PRG Shackles (
Still need to install these...)
