Re: Stock Grill Removal -- low side fasteners???
Well here is what I did lay on the ground use one hand to pull out on the front of the grill and use a screwdriver to carefully pry at the same time. that should work for you. When you put the new grill back in take all of the small fastners out of the sub frame on the truck and click them all into the new grill this will save you a major headache (which I found out  ). just snap back in and you are dialed in.
Big J
07 Titan White,BT,OR,SE pop,4x4,Procomp stage 1, PC Trac Bars, 35" Cepek's, Nismo CAI, Stillen Trans Cooler, Hid Club, Remote start,Flowmaster 50, VK-PRO
05 Maxima SE
07 GSXR 750
