Old 10-10-2007, 04:52 PM   #3 (permalink)
XETEX
XETEX's Avatar
Re: Stock Grill Removal -- low side fasteners???
Originally Posted by BigJ
Well here is what I did lay on the ground use one hand to pull out on the front of the grill and use a screwdriver to carefully pry at the same time. that should work for you. When you put the new grill back in take all of the small fastners out of the sub frame on the truck and click them all into the new grill this will save you a major headache (which I found out ). just snap back in and you are dialed in.
Thanks for the response! -- from the STICKY on the Grillcraft install, it says you must squeeze these connectors from the back side -- that would be great, if I could get to the backside of the lower fasteners -- there is absolutly no way to do that without removing a lot of other equipment in the way.
Just wondering what I'm missing on these lower 2 fasteners.
Black 07 CC XE
XETEX is offline   Reply With Quote
