Re: Will factory warranty cover axle seals if True-trac is installed?
The only difference between rape and romance is the presentation.
If you're cool with them,it shouldn't be a problem.The Tru-Trac did not cause the seals to leak.If in doubt,why don't you have them changed while they are installing the Tru-Trac?
