Old 11-01-2007, 06:36 AM   #9 (permalink)
roy365
roy365's Avatar
Re: Wheel spacers: Good or Bad?
Originally Posted by ORTitan
I have more than 20k miles with no problems running 1/2" spacers on the front with the stock wheels. I did use longer studs from Moroso that are stronger than normal studs. You want to use a hub centric spacer, if not you may have vibrations like I did with a regular spacer.
Those are nice there!!!! Where did they come from??? What kind of vibration were you having?
I had to use 1/4'' spacer on my front's when i installed my Brembo brakes. Also i had to buy longer wheel studs, so plan ahead and buy some if you are doing this work. I have a pair of .50'' spacers at the house if anyone on here wants to try them. PM me if so.
0-60MPH@5.60 & 1/4 mile@14.25 F/S/T
Mods list: http://www.titantalk.com/forums/memb...ml#vmessage205
roy365 is offline   Reply With Quote
