Old 11-17-2007, 02:59 PM   #1 (permalink)
gyrate
Levelling kit and strut holes alignment
So far so good but i decided not to take the strut off the control arm (the 22mm bolt) and mounted the spacer on top with the strut still on the lower control arm, pushed the strut back in but i can't bolt it because the holes don't line up with the top mounting area...
Should i take it off the control arm and rotate 180 degrees for the holes on the top to match? You know how the new holes are offset and mine won't line up right now.
Basically i am asking if the holes on top will line up if i remove the strut from the control arm and rotate 180 or if i'll have the same issue again?
ps. its the prg kit
My TT status expired! Time flies! Please don't thank me in any posts. I never cared for that nonsense and in fact hate it. So dont do it!
gyrate is offline   Reply With Quote
