Re: Rear axle seals leaks. Please report.
Originally Posted by whiteLE
Two questions for folks (especially for those who have had failures):
1. I wonder how much of a correlation there is between leaky seals and a complete rear end failure? (have those with complete rear end failures--found leaking seals at the time failure or are they completely independent quality issues)
2. Do seals leak very gradually or once a leak begins will it often quickly get worse, resulting in much lower rear diff fluid level thereby causing the rear diff to fail sooner? (would a person be better off to ignore the leak and avoid seal replacement in hope of getting new axle/new diff down the road?)
thanks------please comment
white
I've lost both seals but still have the org diff. 35,000 miles
PRG 2" front lift. 1" rear drop shackles
Wet Okole Front seat covers
