Re: Titan 2008.5 - Whats different from 2008?
the dipstick will be a thing of the past....
found this propoganda from Ford. Ford calls it a "sealed tranmission"
Another major change is in what cannot be found under the hood - a dipstick. The new transmission is sealed at the factory with 11 quarts of a semi-synthetic blend of specially formulated fluid that should not require service for 150,000 miles. This is a benefit to owner convenience and the environment.
Because Explorer is the first Ford SUV with a sealed transmission, it was subjected to a series of brutal lab and real-world tests. Some tests were conducted in Ford's Research and Engineering Center in Dearborn, Mich., where the transmission was run for 50,000 miles at speeds of 115-120 mph on a dynamometer.
2004 4x2 SE CC BT
