Old 11-27-2007, 07:38 PM   #12 (permalink)
Titan671
Titan671's Avatar
Send a message via Yahoo to Titan671
Re: How to disable Low Tire Pressure Monitor LIGHT?
Since getting a set of aftermarket rims, I have not had a problem with the low pressure sensor light turning on. I had originally installed the OEM sensors on the aftermarket rims, but due to the angle of the OEM stem valve, I couldnt use them. I inquired from the tire shop if that would set off my sensors. The tech informed me that since the OEM spare tire still had a sensor, the ECU will still read it as if I still had my OEM wheels on. I didnt believe him, but its been a year now and the low pressure sensor light has not turned on. I was kinda suspicious so I reinstalled my OEM wheels. After running them for a week, I ran over a nail and started a slow leak. After a day or two, the low pressure sensor light turned on. I refilled the tire with air about 40 psi and the light turned off after driving it for several minutes. I guess the tech was right..it worked for me.
2004 CCB LE w/ tow package
UpRev and Osiris tuned with supports from Chris and Randy and the member of TT and CT.
Titan671 is offline   Reply With Quote
