Originally Posted by EVO8
I've got the PRG bump stops and you have to drill the existing whole to fit the new bump stop. I installed my bump stops without lifting the truck. You should have more then enough space to work under there with the leveling kit on.
Same here with the NCD kit, drilled out the holes a little, but jacking up not necessary. Check out some pics here:
NCD Level Install
