Old 11-28-2007, 09:22 PM   #9 (permalink)
loufish
loufish's Avatar
Re: I want a lift, but a small one...
With PRG's lift spacer up front and the Deaver 2.5" mini pak in the rear you'll get a lot of bang for the buck...If you can budget it, get the replacement Bilsteins all around.
This will give the rear some lift, add some spring rate to help with loads and towing, all the while getting rid of the factory overload leaf which blows for ride control.
If you have a real sag issue, then I suggest air bags, but try the Deaver Mini-pak first along with the Bilsteins...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
