Originally Posted by crash519
I've got a low speed moan in the front end when I touch the brakes, especially when I an turning and using brakes. I pulled into a fast food drive thru and the poor guy working the window ducked when I pulled around the corner  It seems to be worse after a long drive. I am leaning towards brakes, but it could be bearings since it is cyclic and worse when turning. Any ideas before I go to the stealership? I like having ideas before I listen to their BS
Thanks!
Im having the same exact problem as you described...I'm curious as to what it could be.
