Re: How to disable Low Tire Pressure Monitor LIGHT?
Originally Posted by Titan671
Since getting a set of aftermarket rims, I have not had a problem with the low pressure sensor light turning on. I had originally installed the OEM sensors on the aftermarket rims, but due to the angle of the OEM stem valve, I couldnt use them. I inquired from the tire shop if that would set off my sensors. The tech informed me that since the OEM spare tire still had a sensor, the ECU will still read it as if I still had my OEM wheels on. I didnt believe him, but its been a year now and the low pressure sensor light has not turned on. I was kinda suspicious so I reinstalled my OEM wheels. After running them for a week, I ran over a nail and started a slow leak. After a day or two, the low pressure sensor light turned on. I refilled the tire with air about 40 psi and the light turned off after driving it for several minutes. I guess the tech was right..it worked for me.
Hmmm. I had my little 17 in chromies put on when i bought my truck and they were also designed to were i couldn't use my sensors.. And my dam light has been on ever sense.... It irritates the sh*t out of me...
 "" If it won't take it, i dont need it.. ""
06 Smokd out XE KC
Born- 3/06
Takn advantage of- 4/06
