Originally Posted by Stormwolf
I've heard it all over said that putting an air filter, or installing a better exhaust will increase MPG's because they also increase power so at lower speeds and RPM's the engine doesn't work as hard and thus you save fuel. Any truth to this? And if that's true, any suggestions to parts?
Suggestion.......go buy a Fram or Airraid drop in filter. Maybe reset the ecu, and log your mileage vs. before. That way you can inexpensively try an aftermarket part and see. It will be minimal to low usually. Then if you do see some increase you might go and spring for the exhaust then?!?!
