Re: 08 with death wobble & vib
Who is WE? You mean, you are lost and need step by step instructions?
If the valving in a specific shock setup is too stiff within 10% of the center or rest position it will transfer the oscillation of the wheel/tire assembly into the frame. Tire and wheel packages are not necessarily perfectly round even when road forced and balanced. By process of elimination this can be verified on the vehicle in question. The same truck with the standard set up does not exhibit the "wobble".
As to the tech line. They will deny any knowledge until the engineering department catches up with the real world. Then again, they don't have to deal wit the customer that wants his new bay fixed, NOW.
Rich
