Old 12-04-2007, 03:38 PM   #29 (permalink)
HudsonValleyTitan
HudsonValleyTitan's Avatar
Re: 08 with death wobble & vib
Originally Posted by eagle sg
Who is WE? You mean, you are lost and need step by step instructions?
If the valving in a specific shock setup is too stiff within 10% of the center or rest position it will transfer the oscillation of the wheel/tire assembly into the frame. Tire and wheel packages are not necessarily perfectly round even when road forced and balanced. By process of elimination this can be verified on the vehicle in question. The same truck with the standard set up does not exhibit the "wobble".
As to the tech line. They will deny any knowledge until the engineering department catches up with the real world. Then again, they don't have to deal wit the customer that wants his new bay fixed, NOW.
Rich
"WE" meaning...everyone here who's basically said the same thing to you! You may want to look at all the posts here. You talk in circles, making yourself look like the typical "I'm a Nissan tech" poser we've seen here time and time again.
"If the valving in a specific shock setup is too stiff within 10% of the center or rest position it will transfer the oscillation of the wheel/tire assembly into the frame. Tire and wheel packages are not necessarily perfectly round even when road forced and balanced."
What an absolute compilation of twisted garbage! Do people where you're from actually buy your line of unfactual BS? Call it what it is...It;s the wheel/tire setup or driveshaft issue! That's been said all along. It has NOTHING to do with the shocks. Nothing a shock can do will cause the vibration mentioned. Wheel hop from bad shocks is entirely different. There's nothing NEW on the 08 that should be a problem, other than the wheels/tires. The rest are all carryover parts!
- Joe
