Re: Navigation VSS Wire Switch
this is all i have but its for an 06.
Wire/Function Colour Location/Description Polarity
PASSIVE ANTI-THEFT YES TRANSPONDER SEE NOTES
12 VOLTS Green Ignition Harness +
IGNITION Black/Red Ignition Harness +
ACCESSORY Red Ignition Harness +
STARTER Brown Ignition Harness +
STARTER 2 Lt.Green Ignition Harness +
KEY SENSE Red/blue Ignition switch harness +
TACH SIGNAL SEE NOTES AC
This vehicle has independent coils, there are three wires per coil, White/Blue, Black and the third is the tach signal wire.
FUEL INJECTOR Opposite of White At any injector on engine AC
LOCK Blue At switch inside driver's door -
You must run wires into the doors to connect to these wires. The first pulse on the RED will disarm and a double pulse will unlock the doors.
UNLOCK Red At switch inside driver's door -
DOORPIN SEE NOTES
Driver's door is LT.BLUE, front passenger door is RED/BLUE. The left rear door is RED/YELLOW and the right rear door is RED/WHITE. All 4 wires are (-) and found at the BCM on the right side of the steering column.
R.A.P. SHUT DOWN Lt.Blue SEE NOTES -
This vehicle is equipped with automatic headlights that will stay on after a remote shutdown.you must pulse the drivers doorpin wire to shut the lights off. Drivers doorpin is Lt.Blue at BCM on right side of steering column.
FACTORY ARM Arms with lock wire
FACTORY DISARM Disarms with unlock wire
BRAKESWITCH Red/Green At brake switch +
PARKLIGHTS Red/Blue At dimmer switch +
HAND BRAKE Green At switch on handbrake lever -
HORN Red/White At steering column harness -
VSS WIRE White/red Behind instrument panel AC
Available Notes
Vehicle Notes
PLEASE NOTE: This vehicle is equipped with a TRANSPONDER passive anti-theft system. Please refer to the appropriate security diagram before any remote start installation.
third coast titans
