a .625" spacer AFTER the factory 2" that the DR's are set at? or a .625" spacer with stock shocks? i have my DR's set around 2.5" right now. basically why i'm asking is i would like to fit 315/70/17's with no issues while having my DR's around 3" and the camburgs/spacer. sound good?
You can set the ride height what ever you want, the shock length determines if the UCA/ball joint will be an issue or not.
Since the DR's are stock length, and the stock UCA's can handle a .625" spacer, the Camburgs should be "way fine"...IIRC the motion ratio is 3:1 so a .625" spacer should give you about 2" of lift...
