Old 12-05-2007, 10:47 PM   #4 (permalink)
loufish
loufish's Avatar
Re: 2005 LE w/OR - tow capacity?
My 04' manual has the LE CC at 2 different tow ratings:
Non B/T - Towing capacity 7200 lbs
GCVW - 13,000 lbs
B/T - T/capacity 9200 lbs
GCVW - 14,800 lbs
With the right tires the O/R package has the same gear ratio as the B/T and the same cooling package...SO you should be able to tow as a B/T rated truck..
I highly recommend the factory hitch kit, it comes with the correct factory rated hitch, the bolts and relays for the trailer lights.
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
