Re: How To: Installing AEM Bruteforce Intake
You can save some time and energy by not removing the tire well...All you have to do is cut thoe plastic gromment and then after you get the box installed you can wire tie them back into the holes......and the instructions tell you to remove the washer bottle, I can tell you there is no need to do that step.
Is that the old style oiled filter......the dry flow is a white filter.
Hope these two steps help someone down the road.
2007 White XE KC
Magnaflow Exhaust
2.5 Leveling kit
Tech12volt box dual 10
1200 Watt RF amp
Tweeters added to A-Pillars
Stock air box mod
18" LE 6 spoke wheels
Mods to come
PRG 4" lift
35" Pro-Comp
