Old 12-08-2007, 04:18 PM   #3
helomech
helomech's Avatar
Re: How To: Installing AEM Bruteforce Intake
Originally Posted by rgregory1965
You can save some time and energy by not removing the tire well...All you have to do is cut thoe plastic gromment and then after you get the box installed you can wire tie them back into the holes......and the instructions tell you to remove the washer bottle, I can tell you there is no need to do that step.
Is that the old style oiled filter......the dry flow is a white filter.
Hope these two steps help someone down the road.
Nice write up, that will probably help others alot. That is the dry flow, mine isn't white either. It is a grayish color.
helomech is online now   Reply With Quote
