Old 12-08-2007, 08:22 PM   #3 (permalink)
1bigwhitetruck
1bigwhitetruck's Avatar
Re: Interior Finish Problem
Your probably going to have to match the color up at the auto paint section of your local auto parts store. You will have to pull the air bag off in order to remove the audio and cruise control plastics, but from there you can do as you want with them. I don't remember but I think the steering wheel may have to come off as well. You will see once you get the bag off. As for the door handle I'm going to assume its the strip that runs vertical on the pull to close handle. That will come out with a mini flat screwdriver if you pry one of the corners out, it just pops in. Or. You can call arround to some junk yards and see if the have some clean ones for sale. Or. You can look online at the faux wood trim, carbon fiber, etc that goes over all the panels That sticks on and that should not rub off. Use what you need and loose the rest in the garage. Hope this helps you.
2007 Nissan Titan CC 4x4 LE, -Daily Driver. Nismo CAI, PowerAid tb spacer, 2 degree advance, 2" Ready lift front kit 1" rear blocks, 35x12.50r18 Toyo open country m/t.
2005 Nissan Titan KC 4x4 Off-Road, -Not so daily driver. Stillen supercharger (3rd motor currently broken), AEM CAI, Custom tb spacer, 2 degree advance, Jba Headers, No cats, 3" straight pipe, 5" RBP tips, true dual exhaust, Pro-comp 6" stage 1 lift, Daystar 2" spacers, 3" custom body lift, Custom rear springs, Modified dana 60 rear axle w/4.88 gears, Modified front GM diff w/4.88 gears, 38.5x12.50r18 Pro-Comp Xterrain. Bare foot gas pedal (one day I will actually fix it and be able to drive it again)
1bigwhitetruck is offline   Reply With Quote
