Old 12-09-2007, 01:35 AM   #9 (permalink)
NorCal 4x4
NorCal 4x4's Avatar
Re: post pics: 35's w/ level kit
Originally Posted by yscty
The reason I'm asking is that I have the AR MOJAVE TEFLONS and was gonna go to a black powder coated stock OR wheel but am not now and am still gonna run the 315/70/17 I think, or it might be the 305....Having trouble finding someone with the same set up to see the outcome tho. I have no problem with PWM if need be............
BTW - yes I do have the 2" leveling kit.......
Well two things in your favor. First the 17" BFG ATs are only 34.5" if you have the 315/70/17s, and second they are not as wide as the 315 sounds, only 11.8" wide on an 8" and 11.6" on the 7.5s.
You will definitely have more cutting to do if you go with the 8" 4.5" b.s. Mohs, since you will be sticking out 7/8" more than the O.R. due to b.s. and another 1/2" due to the width of the Mohs.
With the stock O.R. and the 34.5s, some don't even need the pwm, but some do. Add 1.375" more wheel sticking out and you will definitely be cutting, but maybe it's enough ... hope so, and think so ...
