Old 12-12-2007, 07:18 AM   #15 (permalink)
cneary812
cneary812's Avatar
Re: Losing gas mileage; HELP!
another thought. Have you checked to see if you have a sticking brake caliper or parking brake? The other obvious stuff I left out because you said in your first post that you took it in 2 times to the dealer. If the tech has half a brain he would have checked those things out already (fuel filter, injectors, tires, brakes, MAF, etc) but we all know that most of them dont have half a brain so you may want to dump a can of complete fuel system cleaner in the next tank to see if that helps.
05 LE Crew Cab Smoke OR 4x4
airbox mod with K&N
Scangage2/blendmount
Roadmaster Active Suspension
NCD leveling kit installed 3/10/09 Thanks Adam!!
MVP Titan sticker on 3rd brake light.
2º Timing advance, Thanks John! 11/14/09
future mods - JBA Evol , Injen Powerflow, and more
cneary812 is offline   Reply With Quote
