Old 12-22-2007, 05:40 PM   #1 (permalink)
AgTitan06
AgTitan06's Avatar
Removed my sway bar tonight
Well, I removed the entire swaybar assembly today (only 6 bolts 17mm), and so far I'm pretty impressed with how it handles. With my Radflo 2.0's, I don't notice much body roll at all. I even went in some u-turn underpasses and kept up my speed, and while I noticed a difference in handling, it was a good difference in handling. The body roll was minimal because of the coilovers. This "mod" is not recommended unless you have aftermarket coilovers because your springs are whats keeping the truck from having a lot of body roll, and the stock springs are very weak. Little swaybar was a heavy little sucker. Felt like at least 20 pounds. If you're lifted with coilovers, and are on the fence about doing this mod, I'd recommend it. The truck takes bumps and rough roads even better now.
