Old 12-28-2007, 09:37 PM   #22 (permalink)
EVO8
EVO8's Avatar
Re: Best front coilovers?
Originally Posted by PrerunnerGreg
On a 4wd, the Deaver/PRG mini-packs work very well, but offer a bit more height than most guys want. The 4wd spring is much better than the 2wd spring to start with. So to save money, time, etc, I will typically recommend just a shock upgrade for the rear of a 4wd (to match the front coilovers/uca combo) and maybe a small block. Now, a 2wd is a different story. I highly recommend the spring upgrade for these.
Good to know Greg. Thanks! I guess after I install my SAW's and Camburg UCA's, I'll have to determine if my rear end is high enough. I'm already running the 1" block but I like the rake look.
2006 Titan XE 4x4 (PRG 4" Performance package)
2003 Evolution VIII (358awhp/354awtq) that's on 91octane,stock boost, stock turbo.
2007 GSXR1000 (not enough road to touch redline)
"Dream as if you'll live forever, live as if you'll die tommorow" : James Dean.
EVO8 is offline   Reply With Quote
