Old 01-03-2008, 08:37 PM   #2 (permalink)
Titan-ization
Titan-ization's Avatar
Re: Tire pressure sensor light
I had the same thing happen to me. All I did was let out about 5 # from each tire, then reinflated them to about 40# all the way around. Drive about 2 or 3 miles, turn off the truck, then the next time you drive the truck, it will reset itself and shut off the light. I think the cause is sometimes moisture gets trapped in the valve stem giving it false readings, so you need to purge the stem and reinflate to desired psi. That's what worked for me. Also, if you have a pressure monitoring sensor on your spare, you might want to check it also....I have seen the spare be the culprit in the past on other friend's vehicles.
www.burtonwireless.com
2005 Nissan Titan KC SE 4X2 Tow package, popular package, drop in bedliner, running boards, 2* advance, 18" wheels, Rear sonar, adjustable pedals, 6-disc in dash CD, full frontal brush guard, heated mirrors, head mounted driver info center, auto adjust rear view mirror, home link system, Flowmaster Super 44 hidden dual exhaust, Cobra LTD 29 40 channel CB with dual antennas, tool box w/ black diamond plate
Titan-ization is online now   Reply With Quote
