Old 01-04-2008, 01:05 PM   #17 (permalink)
TravisDTD
TravisDTD's Avatar
Re: Tire pressure sensor light
Temperture effects the pressure for sure. If your pressure is set close to the warrning limits of the sensor Driving on the Hwy is enought to warm the tires up a few PSI. After you stop the tire cools again. Forget the cheap pressure gauges, get a good one and reset all your tires. (note that major elevation changes can effect the pressure in your tires too. -food for thought)
TravisDTD is offline   Reply With Quote
