Re: Anyone using a cold air intake while towing?
you may not notice a difference in torque. under normal driving. but i bet you will when pulling a load, depending on the boat size. I added a super stock kit to mine and it changed the low end a little, but i'm towing a 5500lb deck boat. so i put it back to stock. some things the factory does work best for all conditions.
05 4X4 LE
BIG TOW
BLIZZARD WHITE
ACTIVE GROUND KIT
BILLET GRILLE
AVS BUG SHIELD
LAZER LITE TONNEAU
HELLWIG REAR SWAY BAR
LED TAILLAMPS
RANCHO RS 9000 SHOCKS
