Old 01-31-2004, 06:52 PM   #5 (permalink)
karlconnell
karlconnell's Avatar
I never noticed that but I doubled checked the manual to make sure and you're correct. However, I think Darryl is right, it's probably due to the smaller tires as the drivetrain components are the same on all models without the tow package. They may have a max load of say 2,100 lbs whereas the Goodyear SR/A's have a 2,600 lb load rating.
I'm thinking about getting the BFG AT TA/ko's in LT285-65/18 D's (same height as the stock Goodyear's) when they hit production in a couple of months for the additional load rating and added stability for towing. If you look on the door panel it will tell you the gross axle weight rating (GAWR) for the front and rear. I have the tow package and GAWR's on mine are 3,300 (front) and 3,800 (rear) for a total of 7,100 lbs. Yet, the gross vehicle weight rating (GVWR) for my truck is 6,400 lbs becuase of the load range of the "P" rated tires.
Hope that makes sense...
Karl
2004 Titan SE CC RWD, Canteen
Utility Bed Package
SE Preferred Package
Sliding Bed Extender
Sliding Tool Box
Hood Protector
2003 Toyota 4Runner 4x4 V8
2004 Arctic Fox 22H Travel Trailer
Truck and RV
karlconnell is offline   Reply With Quote
