Old 01-06-2008, 05:15 PM   #16 (permalink)
loufish
loufish's Avatar
Re: Anyone using a cold air intake while towing?
I can definitely tell you that stock trucks/cars from the factory run so rich that an intake will not lean it out that much.
Where do you get your info?
They run rich for max power under WOT, but other then that they're not rich at all...They also have the ability to compensate and run richer or leaner as needed.
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
