saw one....
I saw a crew cab 2wd at a nissan dealer with the daystar 2 inch lift and had 33/12.50/r16 tires and wheels, the 33's i thought it didnt look right, not enough space on the wheel wells, the perfect set up would be the daystar lift and 31/10.50/r16 w/ 16 x 8 wheels, because the stock tires that come w/ the titan r, 245/75/17 (well that tire measures 31.8 inches in diameter, but only 8.4 in width...if u put the 31/10.5/r16 w/ 16x8 wheels you will have the same size tire but have a wider stance. it will look beefy but proportioned.
