Old 02-08-2004, 03:48 PM   #2 (permalink)
Sabre66
Sabre66's Avatar
Originally Posted by RedMunsta
If anyone is having problems with the RF radio reception or performance, you should call 1800-nissan1. I did and they said I was the first person to register a complaint about the problem. My FM reception is terrible, especially when moving. The dealer check the connections and could find nothing wrong with that. The dealer contacted Nissan for some guidance. I was pleased to find that the dealership was so progressive. When talking to the Nissan rep, he said that Country Nissan had called in with the problem. Sounds like the type of service department that will do good by me.
Anyhow, Nissan needs to see how widespread the problem may or may not be, so call if you have the radio problem.
The main problem i've found is that the radio doesn't sound nearly as good as CD's do. The system doesn't even play the bass when the radio is on. When you toss in a CD though it's like a concert hall.
Not sure what the problem is.
Sabre66 is offline   Reply With Quote
