Old 01-18-2008, 10:17 AM   #8 (permalink)
miketan
Re: Front end noise after leveling kit install
Check the eccentric cam adjustment bolts for the LCA's if you have them. One of mine got stripped after getting the front end alignment done at the dealer when I got the leveling kit installed. One of bolts eventually worked itself loose and then made clunking/knocking sounds whenever I went over bumps particularly in off-camber situations. It also wreaked havoc on the front tire wear producing lots of feathering on the outside edges of the tires.
'05 Titan XE
K11 Smoke
18" LE wheels-Leer 700 tonneau cover-Ram air hood scoop-SRT-10 rear spoiler-PRG leveling kit-OEM bodyside moldings-OEM foglights-Dunder upper/lower grill-Painted brake calipers-Stainless exhaust tip-Hellwig rear swaybar-Armada front airdam-Rear storage bin-All weather mats-Microfilters-Alarm with power door locks-Hood decals-Fram airhog-Tint.
Coming soon: Painted rear bumper-Bullydog-OEM bed extender....
miketan is offline   Reply With Quote
