Re: radiator fluid
Mine was leaking also but ended up being the radiator leaking. If leaking from the cap, you should see it comming from the cap. If no visible fluid near the cap, bad radiator or a leaking tubing connection or bad hose . When I had mine replaced, the dealer said he always keeps 2-3 in stock to replace bad ones. Must not be just a few problems.
Robert Louis Stevenson
