Old 01-22-2008, 07:48 AM   #7 (permalink)
cneary812
cneary812's Avatar
Re: Thermometer accuracy
Originally Posted by Bootzon
I'm noticing my thermometer for the external temp is like 5-8 degrees too cold. Think I should have the dealer replace this?
What's everybody else's experience?
Thanks
Accurate? how do you describe accurate? Are you looking at you thermometer on you window? How do you know that the thermometer you are referencing is not off, or that the temp is different in that spot? I mean if you want accuracy pay $400 for a NIST calibrated thermometer and you will see accuracy otherwise its all just close. If the thing shows its around freezing drive carefully cause the roads may freeze, if it is in the 100s its hot outside.
05 LE Crew Cab Smoke OR 4x4
airbox mod with K&N
Scangage2/blendmount
Roadmaster Active Suspension
future mods - JBA Evol , PRG leveling kit, 2* timing advance, Injen Powerflow, and more
cneary812 is offline   Reply With Quote
