Old 01-22-2008, 10:53 PM   #15 (permalink)
TitanTech659
TitanTech659's Avatar
Re: Tire Size/Odometer/Speedo Correction...
It is not possible to recalibrate the speedo on the Titan. Also you can use the tire pressure sensors on some but not all aftermarket wheels. It depends on the hole that the valve stem goes in. It doesn't matter what the psi rating is on the tires as long as all the tires are set to the same pressures.
TitanTech659 is offline   Reply With Quote
