Originally Posted by Riverratt
Take this test:
Go to a Nissan dealer and look at 5 different Titans. On each truck check the following items:
1) front door seals mounted on the cab. Look for folds / wrinkles
2) gap between outer aft ends of bumper cover and fender, left and right sides. Varies side to side and truck to truck.
3) forward end of sealant which covers the roof splice on the RH and LH sides (in the channels). Width and taper varies on the forward ends.
Good luck finding two alike. Whan a design has not changed since 2004 and there is still this much variability from side to side and truck to truck, I'll let you draw your own conclusions.
Never heard of tolerances and specs I see. When you find any of those *out of spec* (Do you even know what the spec is?) let us know.
As if that has *anything* to do with being built in MS anyway. Go climb back into your prejudice cave.
