Originally Posted by Doghouse
When deciding on the tire size, you should take into consideration the cost of having the speed sensor reset.
to get the same or nearly so speedo, use this formula:
Height =
Width/25mm : This converts everything to inches easier to understand
previous/aspect ratio: this is the second # = sidewall height
Sidewall+sidewall+rim = tire height
If you change the height by 1 inch this averages 2.5 mph which also adds lots of miles to your odometer and depreciates your vehicle faster.
Hope this info helps with your decision. I used to work in the tire industry.
Very good info. Any idea how much it cost to have speedo reset? I'm assuming the dealer or a speacialty shop can do that.
Thanks.
