Old 01-26-2008, 11:54 AM   #215
wanatitan
wanatitan's Avatar
Red face Re: Rear axle seals leaks. Please report.
Well I went through the SHAME of going to toyota to buy toyota parts to fix my titan.
Gotta do what ya gotta do!! They had to order it.
I did check the diff fluid and found it low.
I too took off the check cap and had a rush of vacuum when I removed the filler plug! I drove to work Let the truck sit about 3 hours before the check!
My other concern is- Ive read on this fourm people say the book says the rear end fluid is suppose to be 80-90 gl5. Lots of you are putting mobil 1 synthetic 75-90. Well when I climbed under my titan, the differential cover is stamped "USE 75-140 SYNTHETIC OIL ONLY!"
Is this a replacement axle???
Well let me know what ya think!
I think I should use whats stamped right on the axle!!!
wanatitan is offline   Reply With Quote
