01-30-2008, 03:01 PM
#15 (permalink)
Re: Allignments, Camber Bolts, & Leveling Kits
Originally Posted by gnonice
More caster, heavier steering, better "return to center feel" after turning, better tracking. I was thinking there was an adjustment with the lift kit that was installed?? Tell ya the truth, I only had to adjust the toe after I installed my leveling kit.
On many vehicles, you can adjust the upper or lower control arm (pivot) front to rear via cam bolts, etc. Again, I've never aligned my Titan (let alone installed a lift kit) so I'm not sure whats there. On my GM there are cam bolts that let you move the front of the upper arm different from the rear of the upper control arm, in effect changing the ball joint center line. Kinda like the "old" RWD cars with shims. Same theory. Move the front of the arm outward & the rear of the arm inward (via shims or cam bolts) evenly increasing caster while not changing camber. Moving unevenly will cause camber to change also.
Interesting!!! Good info to process!!!
The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government. - Thomas Jefferson
