Old 01-31-2008, 10:35 AM   #5 (permalink)
Derwud
Derwud's Avatar
Re: Towing a 31.5 Travel trailer
Originally Posted by dcracing2
Whats the difference in the brake controllers. I have a reese controller, is that a decent one? What would my true tongue weight be?
I have 35x12.50x18 Toyo M\T's are they considered a LT tire and are the acceptable for towing.
One at a time.
Not sure, but if is working for you, use the reece, the prodigy just offers some advanced features and works really well. (No manual set-up, the abilty to be mounted a lot easier since severe angles don't effect it as much, boost control and a few other nice touches)
No idea on the tounge weight, but what ever is listed, double it to be safe.. As for dry weights, most are listed without options and if you have a long option list, well then you have a much heavier trailer. Check the cabinets of the trailer and see if you can find the trailers weight sticker for truer dry weight. I just plan on being at max GVW of the trailer no matter what and it safer that way.
More than likely it's an LT tire, but check Toyo's website to be sure.
'05 4x4 SE, O/R, Big Tow, Rear Video (Kids favorite option). Stillen Grille, AMP Powersteps, SAW's all around, TC UGA's and Rear Shackles, Modified Deaver Mini Pack, Air Bags, Moto Metal 951's 18x9, BFG A/T 285/65-18's, Air Box Mod and K&N drop in, Gibson Exhaust, PML Rear Diff Cover and Trans Pan. Towing WW FS2300 Toyhauler and all the toys.
The Rhino, The Titan, Truck and Trailer
I HIGHLY recommend PRG Products, SDR Motorsports, Desert Works Fabrication, Live Wire Whips, and Gibson Exhaust
