Originally Posted by crash2045
There is absolutely no problem runnin 4x4 on dry pavement for only a few miles. 150 is another story. I run mine on icy roads all the time and low and behold I get better, more balanced traction. There is very little weight in the bed of the titan on the front is another story it helps imensly and keeps your backend under you.
You'll feel differently after you have to pony up the cash to fix your front axle or transfercase. It's abuse to use part-time 4WD on dry pavement and will cause premature wear and failure of drivetrain components due to excessive forces and shock loads being put on them. If you have "a few miles" of dry road then take it out of 4wd, it's not that hard. Just twist the knob.
