Originally Posted by boya544
. Besides you could tie the strap in a knot if it did break.
I'm sorry - but that's REALLY REALLY bad advice.
I'd go with a strap rated for atleast 20,00lbs- and like someone already said- one with loops not hooks.
Thing with straps though is you need to be cafeful not to loop it over an edge that will fray it- and inspect the strap before every use. If it gets wet- make sure you dry it out before storing it.
With the Gr 70 chain- you're never ever going to break the chain- no matter what abuse you put it through- you'll be ripping of truck parts before you ever ding the chain itself. But it bulky and heavy and generally quite a PITA to haul around.
