Old 02-02-2008, 08:10 PM   #16 (permalink)
Winder
Re: Tire Size/Odometer/Speedo Correction...
Do not use the radar systems you see on the side of the road to check your speed those things are never very accurate.
My 08 Titan shows @3mph faster on the speed than it is actually going on stock tires.
If you go to a larger tire size your speed-o will be off by a %. So if the tire you put on is 10% larger then you will always be going 10% faster than what your speed-o reads. SO at 10mph you are traveling 1mph faster than what your speed-o shows and at 100mph you are traveling 10mph faster than what it shows.
There is also @ +/-3mph margin of error for the factory speed-o. Same with most GPS systems.
One of the reasons that police usually do not bother people traveling 5-10mph over the speed limit is that the margin of error of all the equipment involved falls within this range. Laser however is said to be very accurate.
Winder is offline   Reply With Quote
