Originally Posted by Jokers_titan
I have saw more than enough ppl that have this mod done. Myself and a few buddies are wanting to get this done, mainly me at this point due to the little lost with the Banks Monster set up, however we are concerned about the negative effects on the truck as I don't want to mess up a $32K rig. Can you guys shed some light on this. Also can a novice install without any issues. Thanks in advance from us here in Central PA.
It won't hurt anything. The ECU will always retard or advance the timing according to what you're driving style is and the fuel you're feeding it. The advance is also within Nissan specs and will not kill your warranty. I believe that there is actually a +/- 5* of timing that can be changed from factory settings without hurting your warranty.
So - the pros are that once you add an exhaust and an intake you'l really feel it. The cons are it's hard to find a dealership that has the proper Consult III that will do it for you without charging an arm and a leg for shop time.
This mod is one of the easiest and one of the best out there in my humble opinion. Go for it!
Mods: 2* Timing Advance · AEM Brute Force · Burn-out Mod @ ECU · 18" Magnaflow · Nissan OEM Brush Guard · Hellwig Traction Springs · Jason Topper
Wish List: Nerf Bars · LineX Spray-In Bedliner
Waiting For Support On: TruTrac · UpRev
"I can't find anyone to race..."
